top up voucher
Hi, Problem with top up voucher being applied on line. I've entered the digits and clicked "do it" but it still wont show up, even after 6/7 attempts. Have done it this way the last few times and worked no problem.
If you are trying it online then maybe try 1740 or USSD instead as explained here:
At least one person recently could not get it to work online but it worked via 1740.
If that doesn't work then contact PayZone/Omnivend and/or 48 support in case the number is invalid (as also happened to another user recently).
