sim won't register with one plus one phone
conor_cleere
I recently bought the onebplus one phone but my sim won't register with the phone as it does not ask me for my PIN code. Can anyone help me out here? thanks
6 REPLIES 6
Is the SIM registered/activated?
What exactly happens when you put the SIM in and switch the phone on?
Any messages/prompts at all?
Can you scan for networks and see any?
Are you sure that SIM PIN locking is enabeld on the SIM?
Can you use another phone to disable SIM PIN locking and then try it again in the One Plue One phone?
conor_cleere
The phone is unlocked to all networks. I put w meteor sim in and it works just fine! 48 is the only network that does not appear when it was searching for mobile carriers
Does O2 appear?
Can you connect to it?
Or maybe 3 now that they have merged?
Some phones don't recognize some virtual networks such as 48 but you can connect to the "host" network instead.
conor_cleere
It says my sim does not allow connection on this network
conor_cleere
That's what it said when I tried to register with 02
OK - unfortunately I don't really know so.
Any chance there's a more recent software update for the phone that might help?
I do know that somebody else here recently with an OPO had to order a new SIM before it worked for them.
Maybe contact 48 support and see if they can offer any advice?
