signal
Im down in achill island. I have no signal whatsoever just in the last 2 days. It's been fine before now. I've never had any issues. Is there any reason for this?
It is very possible that this is just a short little outage.
In the meantime,
-try::
restarting your phone, removing your SIM card, resetting network settings.
If none of the above help, raise a ticket with an agent; using the link below in my signature!
In the meantime,
-try::
