settings pin
Im trying to access my security code but I can't access my messages because my phone keeps looking for my settings pin.  How do I access this?
Hi 12dodo34
I assume you are using a Nokia smartphone handset. Do you remember setting a code to access your settings ?
Try this link http://www.nokia.com/ie-en/support/troubleshooting/?action=singleFAQ&caseid=FA99671_en_US
This is a problem that is not connected to your 48 membership so may have to try a factory reset on your device if you cannot remember the code.
Yours,
Camille
Community Helper
