roaming not working
hi. i bought the 10 eu roaming minutes and i cant make or receive calls when roaming. roaming is turned on in my phone. please help.
I don't think that you can roam on another Irish network when you're using 48. My understanding is that you have to connect via 48/O2 (48 essentially being an Mobile Virtual Network Operator on the O2 network). If you cannot connect to 48/O2 then I don't think that a roaming add-on is going to help. I'm open to correction on this though. For what it's worth the 48/O2 network coverage is outlined here:
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/What-s-the-network-coverage-like/ta...
What country are you roaming in?
What network are you connected to?
Ireland.
I can connect to IRL- METEOR, vodafone IE.
That doesn't make sense to me. If you are in Ireland then you are not roaming so why do you think you need a roaming calls add-on? In Ireland you just connect to 48 (or O2 if you don't see 48 listed - happens to some people) and make calls etc via your normal membership allowances.
at my house i can't connect to 48 or o2. so if someone is trying to ring me it doesn't come threw. i hope theres some way i can get this sorted out because this is the only problem i have.
