registering new sim- HELP!
rosiephelan
Hi , I have been a 48 customer for awhile now and recently I bought a new phone. I bought a samsung galaxy s3 and it required a micro sim. I ordered my micro sim on the 19th and it only came in the post today, when i tried to register the new sim to my account with my existing number it said I had to deactive my old sim, I did that but yet when I entered the code for my new sim it said I still have an active sim registered. I really don't know what's going on, I can't use my new phone and now my old number is blocked. I really can't afford to go a number of days with no number at all for work reasons.
Can someone get back to me asap, I would really appreciate it.
Thanks,
Rosie
Hi Rosie, not much i can do to help you with this,
but the guys over at technical staff will!
raise a ticket using the link below in my signature!
Hi when I go to click on your link it just says
"An invalid set of parameters has been specified in the url."
Getting seriously pissed off this problem is still not solved. This is a very simple job that has been turned into a complicated mess.
Ridiculous!!!!!
Hey there,
if you're still struggling with this, you can contact the care crew either via this links: http://help.48months.ie/requests/new
Or send them an e-mail to: support@48months.zendesk.com
Regarding the original issue this new FAQ may be of interest as it explains the difference between ordering a replacement SIM (which will immediately deactivate your existing one) and ordering a new SIM and then getting your details transferred over by 48 support:
http://community.48months.ie/t5/Most-Popular-Questions/You-need-a-replacement-SIM/m-p/7234#U7234
