receiving mms on a vertis android phone
nicolehurley
Hi , can anyone help me, I can't seem to receive mms, it's a vertis phone, same internet settings as other android phones , I changed the settings and then when the mms downloaded I got a txt from lifted telecom saying msg to big to download , but yet it downloads on a smaller x peria phone
Make sure that your APN/internet settigns are as follows:
MMS Proxy: 10.1.11.19
MMS Port: 8080
MCC: 272
MNC: 11
APN Type: * or default,mms,supl
stevehurley
Cheers thanks very much , will try this now.
stevehurley
Nicole
@stevehurley wrote:
Nicole
Papa?
