"Error in Connection"
megan202
My texts won't send and when I try to make a call it says "error in connection" and hangs up..
I have membership until 10/10/14 so I don't know what's wrong?
megan202
It also says I have full coverage..
What make and model of phone?
Is it a Nokia by any chance? If so what model?
Did this work at all before?
If so what changed since then?
Can you receive calls/texts?
megan202
It's a Nokia C3-00
Yes I've been with 48 for a year with this phone.
I don't know what changed, I was able to use it this morning at about half 8 and then around 11 or half past I went to text again and it just wouldn't work.
No I can't receive anything either.
I don't know if roaming even works on this, but I didn't change any settings between when it did and didn't work.
If you Google  for "Nokia C3-00 error in connection" you will see some info but nothing that is obviously a panacea.
I would suggest that you contact 48 support and see if they can help/advise.
Do you have another unlocked phone to try your SIM in just to rule out any issue with that?
