q
stefy_88
Hi there! My sim was tesco, then O2, now 48. Is that possible to keep on holding the same number to switch to 3 network now?
Yes - you just ask whatever network you are with to port the old number over.
If you're with 3 now and your number is with 48 then you ask 3 to port the number over.
Thanks for your help!
