please can anyone tell me how to do internet setting for samsung note
pamc20
Hi. Ive a samsung note and need the internet setting can anyone tell me the step by step for it? Thabks x
Try the online configurator:
http://48months.tweakker.com/choose/Samsung
Choose the relevant Note model and follow the instructions.
If that doesn't work then manually configure these settings:
MMS Proxy: 10.1.11.19
MMS Port: 8080
MCC: 272
MNC: 11
APN Type: * or default,mms,supl
This guide should help you to navigate the user interface to configure the settings if you don't know how to do this. Obviously ignore the Vodafone settings mentioned and used the ones above instead:
http://deviceguides.vodafone.ie/web/samsung-galaxy-note-3/explore/internet/set-up-your-phone-for-int...
pamc20
Hi thanks. But how do I get to these settings?? Havent a clue. Thanks 🙂
Did you try the online configurator as I suggested?
The first link that I posted.
What happens when you try that?
If that doesn't work then look at the second link and use it to guide you in manually configuring the settings that I posted above.
