phone internet not working
purchased the don and internet not working on my device?? help please??
You'll need to configure the internet/APN/MMS settings for this to work. See here:
If your device is not listed then choose a similar one or (on Android) try the Tweakker APN app mentioned near the start of the above thread.
7 REPLIES 7
shah
My internet not working in my phone
You'll need to post a bit more info that just that...
Did it ever work?
If so when did it stop working?
Are calls and texts working OK for you?
If not then see this thread where some people who have had no network connectivity at all since last week's rollout of 4G/LTE describe their situations:
https://community.48months.ie/t5/Phones/Service/m-p/52663#M3085
If calls and text ARE working OK then are your internet/APN settings configured correctly?
https://community.48months.ie/t5/The-Knowledgebase/My-Internet-is-not-working/ta-p/45928
Any update @shah ?
meganbd
My Iphone 6 has had "no service since yesterday, have gone through all the Apple procedures and checked sim but still no success, no network available to click into.
You probably need to look at this thread.
https://community.48months.ie/t5/Phones/Service/m-p/52676#M3091
Did that help at all @meganbd?
