network down
network down from 12 noon. no network coverage
OK - you should log it with support so to make sure that they're aware of it.
Working fine for me all day (Dublin central).
Where are you?
Do you get no signal at all?
Or do you get a signal but cannot use services?
Can you send or receive texts or make or receive calls at all?
Any chance you breached the fair usage limits and got barred for the remainder of your current membership month?
Have you logged a support request to ask 48 for assistance?
tuam co galway. no signal at all, cant make call or texts. have checked tesco and lyca mobile sims and there is no network aswell. so as they r runing on o2 network as 48 so it has to be some network issue. membership was bouht today. there r good few more people with same issue
ccorcoran
I have the same problem...
You should log a support query to get assistance from 48 support.
