02-08-2014 07:03 PM
03-08-2014 05:37 PM
Hi @Anon
Assuming you have active membership which is needed for the internet to work, you can input the settings via the online configurator here.
If that doesn't work for any reason, try configure the settings manually - check out instructions here.
Remember to enable data roaming on your phone (if it's not already) as that is needed for internet to work on 48.
Can you reply back to let us know if any of this worked for you? Cheers.
03-08-2014 05:37 PM
Hi @Anon
