my internet not workin
paulao
Look I can't find my phone on the models my phone it's a
LG - f180L E973 I couldn't find it can't send the message so could you please help me cause I really need the internet thanks please help and if u need the number is *****
Edit / personal info removed. -Marion
LG - f180L E973 is an Optimus G so you should try one of the Optimus G models here:
http://48months.tweakker.com/choose/LG
If that doesn't work then download the Tweakker APN app from the Google Play Store over wifi and see if that can configure the phone:
If that doesn't work then try the generic settings here:
Internet Settings
If that doesn't work then contact 48 support for advice:
PS By the way you probably shouldn't post your number in a public forum!
Internet Settings
