internet
ai have a htc hd and the internet not working what do ai do
Did you try the settings for one of the other HTC phones here?
Or Tweakker APN:
Maybe post your settings here in case there is some mistake. Did you enable data roaming?
If nothing else works then you may need to log a support request to get 48 to advise.
Or Tweakker APN:
