internet
mard
hi
i have a sony xperia c1905, i have used the information from this site and i wifi is working - but cannot get the 3g to work - is there some other setting i should be enabling?
any help appreciated
martina
Try the online configurator:
http://48months.tweakker.com/choose/Sony/C1905%20Xperia%20M
If that doesn't work then download the Tweakker APN app over wifi and run it to configure your settings:
If that doesn't work then configure it manually using the settings linked to here:
http://community.48months.ie/t5/Need-Help/ZTE-Blade-3-no-3G/m-p/31087#M10101
Make sure to enable data roaming.
