internet won't work after following online data settings and activating data charges
eskarola
Hello,
I have followed the guidelines online to change my data settings
and I activated the data roaming, but I still don't have internet on my phone.
what do I do next?
Thanks, carol
Are you sure that your internet settings are correct?
How did you configure them?
See here perhaps:
http://community.48months.ie/t5/Need-Help/nexus-5/m-p/33205#M11511
If you review them and they look OK then post them here for review/comment.
Screenshots are best but if you can't post them then list the settings out in detail.
eskarola
Thanks dalye for your message.
The thing is I had internet with the phone number they asigned but when my old number was moved to 48 it stopped working. So I pressume the settings are ok.
Carol
As I said check and maybe reconfigure your settings using the link that I posted.
If they look OK but still don't work then post them here for review.
If necessary contact 48 support for assistance:
