internet settngs fpr xperia P
Hi all .. I have a xperia p and have tried all the manual settings for internet and still no joy. It's there and working on some settings but it's not showing 3g or h logo beside the antenna signal I just updated firmware to 4.1.2 everything was fine till then.... Is there a way to send a SMS to get them sent to the phone .. For the life of me that tweaker appbis **bleep** its not a one click fix like its alleged all it does is give manually settings anyway
11 REPLIES 11
Have you addressed the fact you had zero connectivity problem's prior to updating to 4.1.2...
The tiny R above network bar's is for roaming... that's as it should on 48.
Advice:
Search the net for data issue's after updating firmware 4.1.2...
I'm leaning to a data traffic query subject to the above, & if so, you do not have to re-install Internet Setting's.
If it turn's out to be the case - Your choice's are limited, but have a poke on the net as mentioned to consider what next.
Yup I've addressed everything and still to no avail... I'm crossing them off one by one .. Can't sort the issue so I'll leave it there thanks tho 🙂
