internet settings
pavel94
Hi guys,
Could u please assist to connect the internet for Lenovo X2. There is no instructions for this model.
Thanks
6 REPLIES 6
dc888
Crew (retired)
Crew (retired)
Hey Pavel
That's an android phone so the settings below should work for you.
Open Settings then click MORE SETTINGS
Then click MOBILE NETWORKS
Next click ACCESS POINT NAMES
From here press you menu key which is the touch button to the left of the home button
Next select + NEW APN from here enter this information
Name - 48 Internet
Proxy - leave blank
Port - leave blank
Username - leave blank
Password - leave blank
Server - Not set
MMS proxy - 10.1.11.19
MMS port - 8080
MCC - 272
MNC - 11
Authentication type - PAP
APN type - default,supl,mms
When you have done that ensure mobile data and data roaming are both switched on.
Let me know if that works.
Damian
In my experience Authentication type can (should?) be left blank/not set.
I previously posted this minimal list of configuration settings which have always worked for me on different phones regardless of make/model.
I have filled all fields exept for APN type - default,supl,mms. I dont have it. What should i do, i am panicing....
You mean there's no APN Type field at all?
That sounds very odd.
I've Googled for other operators' settings (in other countries) and they all mention APN Type as a field that should be configured and configurable.
What fields ARE listed?
Can you post screenshots?
Not being smart but have you scrolled down the screen in the APN settings?
Maybe try the APN as it is in case it works?
Name
48 Internet
APN
APN type
default
Proxy
Not set
Port
Not set
Username
Not set
Password
Not set
Server
Not set
MMSC
MMS proxy
10.1.11.19
MMS port
8080
MCC
272
MNC
11
Authentication type
PAP
APN protocol
IPv4
APN roaming protocol
IPv4
Bearer
Unspecified
I don't understand.
APN type IS listed there.
Can you not edit it or something?
Does it let you enter text? If so then enter "default,supl,mms" (without the quotes).
In some cases it presents a list of checkboxes in which case you should select default, supl and mms.
Does the APN work when it's left at default?
Authentication type is irrelevant as far as I know and have seen.
I'd leave it not set/blank.
