internet not working
qulkin
I have full signal .I enabled data roaming. I have 1 gig plus of data left. I have never been able to use it since I joined on the 1st of April. I have turned it on and off and aeroplane mode on and off. I am using a Motorola moto g
Did you ever configure your internet/APN settings?
If not then it definitely will not work.
Try this:
http://48months.tweakker.com/choose/Motorola
and if that doesn't work then manually configure your settings as per this post:
