internet not working
emmasinclair
I have tried everything but my internet wont work put in apn its perfect set up as 48internet have my membership payed have data roaming on but still no internet on my phone..
Did you follow the steps here to configure your internet/APN settings?
I usually find the Tweakker APN the most reliable way to do this.
If you delete any existing APN(s) and then download and run the Tweakker APN app then it should sort things out.
You also need to enable data roaming.
If that doesn't work then post your settings here for comment/review.
I'm having the exact same problem with iPhone 4s. No internet signal at all and since moving to 48 I can't even get wifi so can't download tweaker app
The Tweakker APN app is for Android only so no use here.
But you should be able to configure the internet settings here:
http://48months.tweakker.com/choose/Apple/iPhone%204S
If that doesn't work then try this:
http://iphone.tweakker.com/#home
If neither works then you need to configure the settings manually:
http://community.48months.ie/t5/Need-Help/Apple-iPhones-internet-settings/m-p/146#M1303
I presume that everything else works OK - calls and texts?
