internet not working
Hi I have HTC HD 2. Internet is not working. installed APN setings, tryed with twikker steps and still not working. Can You help me.
Hi!
Hopefully this link will help you out, as that's pretty odd if you put in the APN setting incorrectly!
http://community.48months.ie/t5/Most-Popular-Questions/My-phone-s-internet-is-not-working-Why/m-p/30
Try the online configurator.
http://48months.tweakker.com/choose/HTC/HD2
If that doesn't work then download the Tweakker APN app from the Google Play Store over wifi and run it:
In either case ensure that data roaming is enabled.
I'm assuming that you have a data allowance as part of your membership or a data add-on.
