internet not working
I have prestigio PAP5300DUO i have the steps autho and manually still not working.i have 1GB, do i need to purchase more?
Did you try all of the steps here to configure your internet settings?
http://tinyurl.com/kys43lv
If so and it still doesn't work then you need to contact support as per that link.
You do not need to buy any more data allowance/add-ons.
