iMessage disabled
jill_hanlon
My iMessage isn't working with my 48 number idk what happened bc it was working before!
16 REPLIES 16
jill_hanlon
Yeah sorry I did but I've had to pay €1 four or five times now which I'm not happy with
That's odd.
iMessage activation should only happen once and just needs a single UK SMS costing 25c that the activation mechanism (online or via iTunes) sends automatically.
Are you sure that you weren't doing a factory reset or restore of your device that might have reset it back to a situation that needed iMessage reactivation costing 25c again?
If not then contact 48 support and they may be able to explain:
jill_hanlon
Sorry yes thank you it did!!
Did 48 explain why you needed to topup several times to cover the cost of repeated (?) iMessage activations?
jill_hanlon
They said it was an issue with Apple
Yes but you didn't actually pay €3-4 in activation text charges did you?!
