hi
I have got a new phone but have no internet can you help my new phone is a Lenovo thanks
You need to configure the internet settings (and have a data allowance as part of your membership or add-on):
Internet Settings
Try the online configurator first
http://48months.tweakker.com/choose/Lenovo
If your handset isn't listed or it doesn't work for some reason then download the Tweakker APN app over wifi and run that to configure your settings:
If  that doesn't work then you need to configure your settings manually using the first link above as a guide.
Internet Settings
