help
adamyarr
I put a deal in the wrong number and payed for it and I need it now so what do I do to change it over?
Your query is not clear.
Do you mean that you paid membership for some number other than your own?
If so then you will need to contact 48 support and see if they can rectify this for you.
If that's not the problem then please clarify what is.
