help
Hi iv put my SIM card in to a different phone and it's askin me for SIM network unlock pin abd I don't no what it is iv already tried the pin ??
SIM network unlock PIN has nothing to do with the SIM PIN (PIN1) or PUK.
I forgot my PIN..... What now?
A prompt for SIM network unlock PIN almost certainly means that your phone is locked to another network and needs to be unlocked before you can use it on 48 or any other network:
Unlock guide
Unlock guide
