exchange membership
kiera81
Hey;i would to excahnge my current membership with the one i ve already bought bought fir next month. Does someone knows if it is possible ? Thanks
If the membership has already started then it is not possible.
If it is still stacked and hasn't started then you can contact 48 support and they may be able to sort it out for you:
