dropping downloads
frankmcd
So, teo nights in a row, I've tried to download the same file.
First time, 165 mb of the ~400mb file downloaded. Useless. Had to download full thing again. Just tried to download it again, 24.5mb of it downloaded. Again, no good. has to be discarded.
Do i try to download again? Any chance of getting the 190 odd mb back? Just wondering. Where d you stand with dropped downloads? Where do I stand?
Thanks.
Downloads can fail for a number of reasons including hosting server side issues. It's difficult to say whether or not the 48 network/data connection is at fault here without more information and investigation.
Maybe you should log a support query to ask 48 support about this to check if there's any issue on the network side?
I doubt that they will "refund" you the lost bandwidth but you can always ask...
On a more general point ... for large downloads I would normally try to download over wifi and use a download manager that can resume downloads from the point at which they failed if necessary. Maybe such an app is available for your phone?
frankmcd
decided to try again 24.3mb this time.
Not on.
