cant call or text
my membership hasnt run out but if i send a message it keep saying failed and if i call someone its says turn call barrinf off but i dont no how too?
What does your online account say abour your membership status, expiry date and calls/texts/data/credit balances?
Did calls/texts work before now?
If so did anything change before they stopped working?
Any chance that you have used up your calls/texts allowances?
Any chance that you breached the fair usage limits and got barred for the remainder of your current membership month?
http://www.48months.ie/boiler-plate/terms#18
If necessary you might want to log a support request to get 48 to assist you with this.
