Will my 48 work in spain?
I'm going to spain tomorrow for 5 weeks and I was wonder how will my 48 work? will I just top up normally and it will send texts like any other network abroad?
Yes you can roam in Spain on 48 but you should probably buy roaming calls and texts add-ons as it gives better value for money when travelling in the EU (especially the 0c/min for receiving calls compared to the normal 8c/min)
http://community.48months.ie/t5/The-Newsroom/Cheaper-roaming-rates/td-p/3476/jump-to/first-unread-me...
http://www.48months.ie/pricing
Note that 48 does not support data roaming though.
Oh - and if you're away for 5 weeks then you will probably need at least two memberships to cover you. But I presume that you will have internet access (via wifi on the phone or on a computer?) in order to log onto 48 to top up your credit balance and buy additional memberships and add-ons as needed?
