Wifi not working.
Hi guys, so I switched to 48 today and since I've put my sim in and bought membership, my wifi won't work.
I'm not having a problem with 3G or making calls at all, however when it says I'm connected to wifi nothing will refresh and I can't make it work although it says it is connected.
Does anyone know what this could be?
Thanks!
Can't see how this could be related to your SIM but just to test ... power off, take the SIM out, power on again and see if wifi works. If not then it's either the phone or the configuration. If it does work but not when the SIM is inserted then you may need to contact 48 support:
Any update?
