Where has standard membership gone?
sn
I have been a buying the standard membership since I joined 48 when they launched in Ireland.  My membership ran out today and I have tried to purchase the standard membership but the option is not available to me.  I have never bought any other memership as I always combine the standard membership with an internet add on.  Whats the story?
Just to clarify one thing ... as long as you have been a member before 5th March 2013 then you can buy Standard membership  - even if you buy another membership at any stage. Previously there was a rule that if you ever bought a memberhsip other than Standard then you lost the ability to buy Standard but they relaxed this sometime last year.
11 REPLIES 11
Do you mean mobile calls?
Remember that you only get 300 mins of mobile calls a month with Standard membership since June.
http://www.48months.ie/boiler-plate/notice-of-changes
Standard membership is not worth buying anymore.
You get more with Guido for the same price.
Although still only 300 mobile mins.
Did that help at all
