Vodafone won't give me nac I have an iPhone 4 is there any other decent links to get it unlocked
Why won't they unlock it for you?
It's a while since I did any unofficial iPhone jailbreaking and unlocking but it still comes with caveats and may result in loss of functionality or inability to upgrade to newer versions of iOS etc. But maybe I'm wrong and things have moved on since I was doing this...
If you Google you will find guides and information about how to do this... e.g.:
http://en.wikipedia.org/wiki/IPhone_Dev_Team
I've unlocked/jailbroken a good few iPhones, and have always found it affected the overall performance of the phone.
I'd recommend you get it done in a phone repair shop.... Usually found on the high street of a city/town nearby. Might cost you upto $50 to get done, but i'd rather chance that than kill the battery life or whatever.
Don't the phone shops just jailbreak and unlock unofficially anyway? Isn't the only way to do it properly through the carrier and/or Apple and any other way involves risks and caveats?
