Top up
lewis7545
Just topped up by text and got the usual response your sorted but can't make calls
dc888
Crew (retired)
Crew (retired)
Hey Lewis
Has this new membership been queued?
If you log in and check under your membership planner it will tell you when your current membership ends and the new one starts.
Check that out.
Damian
Was this the problem?
http://community.48months.ie/t5/Need-Help/Issues-with-membership-s-31-May/td-p/35231/jump-to/first-u...
And is it all working for you now?
