Standard membership changes
mike93
Hi just wondering if I buy say 6 months of standard membership in advance now (before the changes come in), will I have the OLD standard membership (all calls and texts) for the whole six months? Or just for this month? (And yes I know it's kinda screwing the system but it's worth a shot)
As far as I know the answer is "yes".
Any memberhsips bought before June 10th qualify for the "old" Standard membership benefits and not the revised ones.
But check with 48 support just to be sure.
mike93
Hey dalyer, yep I asked a 48er as you suggested and they confirmed that you get the old standard membership if you pre-buy now. Thanks for the help
Great - thanks for posting back and confirming that.
Only 5 days left... 😄
