SIM
sarahhanley
I was wondering if it is possible to change from a micro sim back to a normal sized sim. I have a regular sim already and want to use it in another phone as it can't be used in an iPhone, does it have to be reactivated? Thank you
Yes - just go here, choose the "swap" option and select dual SIM (which is a mini/regular sized SIM with a micro SIM popout):
http://community.48months.ie/t5/Most-Popular-Questions/Need-to-swap-your-SIM/m-p/15707
bridie1950
Can I have a replacement sim as the 1 you sent me 2 weeks ago does not work
You'll probably need to contact 48 support and/or just order another replacement sim.
Contact 48 support here
Delete - ignore.
Did you contact 48 support about this so?
