03-08-2014 09:16 PM
04-08-2014 10:56 AM
If you connect to O2 UK and make or receive calls/texts while connected, you'll get charged for roaming! Is your network selection set to automatic? If the 48 signal is weak and the UK signal is strong it will connect to that network without any notification in that case.
Try set your network selection to manual and select 48 - it will stay connected to the 48 network. If at any time the 48 signal is poor, then it will not automatically select the UK network. You'll just remain on 48 with a weaker signal. Will stop any roaming charges from occurring without your knowledge!
Let us know how you get on?
04-08-2014 10:56 AM
04-08-2014 11:54 PM
@marionh wrote:If you connect to O2 UK and make or receive calls/texts while connected, you'll get charged for roaming! Is your network selection set to automatic? If the 48 signal is weak and the UK signal is strong it will connect to that network without any notification in that case.
I think that worked 🙂 thanks for the help
05-08-2014 02:28 PM
