Registering
It wont let me move my number as my sim is being registered/activated for the last two days. I can't use the sim card as long as I have this problem. It said it should only take a few minutes but it still wont let me do anything. I hope you can sort this problem out for me soon , Thanks Pat
It should not take that long to register/activate a SIM. You should contact 48 support to see what the hold up is:
