Pin Code
I have lost my pin code for my sim card , how can i get my pin code ? Thanks 🙂
If you have lost the sim card packaging...(your pin is listed on it)
You need to input a four diget pin to block the sim... yes that's correct!
You then will be asked for your PUK number to unblock...this can be found on your membership page (on my 48).
Enter PUK carefully - or you'll need a new sim!!!
At this point, you will have access to your phone.
See guide below:
http://community.48months.ie/t5/Most-Popular-Questions-Knowledge/I-forgot-my-PIN-What-now/ta-p/256
See here:
Edit: post crossed with previous one.
Hey jamiegreville
Follow up on your query/post...
Did you manage to unlock sim?
