PIN Code
w4nn13
My phone ask for the PIN each time i start up my phone is this normal how do I turn this off? I have a Unlocked Nexus 5
marionh
Crew (retired)
Crew (retired)
Hi @w4nn13
That sounds like a phone security setting. There was another members earlier asking about a similar issue here. For them it seemed to work if you go into security settings and find the SIM PIN lock (or might be called SIM PIN protection) option. There should be an option to disable it from always asking for the PIN.
Did that work for you?
marionh
Crew (retired)
Crew (retired)
Hi @w4nn13
paulinalinek
I nead new pin
See here:
I forgot my PIN... What now?
Did that help at all @paulinalinek?
