No internet when Im roaming.
eilish24
My Samsung Galaxy S3/4 froze and I had to hsve it completly cleared of everything and reload the software sgain. So since that I dont have sny internet when Im roaming I do have internet when Im at home from my own wireless conection. Do I need to do something in the settings, if so can you please send me the settings. ONE OTHER thing but not as imporntant as the internet is I dont have predictive text and cant find a setting to turn that on. The internet is most imporntant. Thank You.
If you mean when roaming abroad then you need to be aware that 48 don't support data roaming abroad.
But if you mean when out and about in Ireland then you need to make sure that your internet/APN settings are correctly configured.
See here:
http://community.48months.ie/t5/Need-Help/problem-with-internet/m-p/34635#M12689
For the predictive text issue see here:
http://www.samsung.com/ie/support/skp/faq/1040718
