Showing results forΒ
ShowΒ Β onlyΒ  | Search instead forΒ
Did you mean:Β
No Internet on Samsung J3πŸ˜•
ibbie
Hey just back from holidays and Internet isn't working on my phone. Tried the tweeker but that disn't even send an sms any ideas? Thanks
8 REPLIES 8
Follow the instructions here to configure your internet/MMS APN settings correctly
Did that help at all @ibbie?
ibbie
No on to support about it. Thanks though! πŸ‘
Are your internet/MMS APN settings correct as per the instructions that I linked to above?
Did MMS receive or send ever work for you before?
ibbie
Yep settings all correct. What's the mms?
Multimedia Message Service.
Basically picture messages or other messages with multi-media content.
ibbie
Oh yeah it worked fine before I went away
Sorry - I was getting confused between different threads and replied to the wrong one - hence the reference to MMS above. Apologies for any confusion cause. Man Embarassed
