Network
Hi I did all the recommended setting changes to change my phone but I only got network for a few seconds snd then no service again . I changed my phone frm a Nokia to a iPhone my email is [personal details removed]
Are you sure that you have a membership or add-on that gives you data/internet access?
Can you put your SIM back into the Nokia to see if internet access works there?
Have you double checked the iPhone settings here:
You probably need to log a support query to get 48 to help you with this:
