Network issues
The network is not as good in our area as it used to be.
When will it improve? Is 48 part if the three network?
You'll need to contact 48 support about this:
48 is a "virtual" network that operates on the Three network but it's basically a separate operation.
Did you get onto 48 support?
Were they able to help?
No. I tried the link you sent me but I dont know where to go after that
Try this:
Thank you, that worked
