Moving to UK
jim_flynn
Hi folks, I'm moving away to the UK in the next few days for a few months and I was wondering what happens with the 48 network. Will I still be able to make and receive phone calls while over there? And if so are there extra charges? Also wanted to find out will I still be able to recieve data. Any help is greatly appreciated! Thanks
If you use 48 while in the UK then you can buy EU roaming add-ons or pay the relevant charges (for incoming and outgoing calls and outgoing texts) from your cash credit balance. See here:
48 don't support data roaming abroad so you're restricted to wifi where available.
To be honest if you're going to be there for a while then you might be better off getting a UK SIM for general use for the duration as it'll probably be much cheaper. Of course you won't be able to use your original Irish mobile number if you do this.
Did that explain things adequately for you?
jim_flynn
Sorry for the late reply, but yes this helped a lot! Thanks for your answer!
