Moving Number From O2
robotross
Hi. I went through the process of porting my number from O2 billpay. It hasn't been 2 hours yet but I was given an 089 number in the meantime. I'm just wondering if that's standard and if the number will change to my old number once the porting request goes through? Thanks
It's normal to get an 089 number with a new 48 SIM.
However if your number is porting then I think it should say so when you log into your online account.
If it doesn't say this but lists the 089 number then there may be an issue.
If this is the case or if it takes more than 2 hours you should log a support query to get 48 support to assist:
How do I keep my old number?
Cool. I went through the porting process again and it now says "transfer in progress" so hopefully that should sort it. Thanks for your help.
Great - hope you get sorted soon.
