Mobile Data
rock_chick
after quite happily using my mobile data on my samsung s3 mini for the past year it suddenly seemed to stop on monday.
I have received the settings text twice and have manually gone through all the settings as suggested and still cannot get it to work.  I have loads of data left on my membership and the internet works fine with my wifi.
Please help i miss my viber on the go.
19 REPLIES 19
Did anything change on the phone?
Software update or something like that?
I've heard other reports of Samsung phones spontaneously losing their internet/APN settings for some reason. Google it and you will see.
If you need to reconfigure your settings then see the options here:
bigjoeod
Regular
@rock_chick wrote:
Data roaming turned on?
Also refer to the above post.
________________________________
If I helped you out, you can help me out by giving me 'Kudous' (The big thumbs up button) and accepting my answer as the solution to your problem.
Slowly putting the laughter back into slaughter..
tried everything - manually put in every samsung settings on the website
reconfigured settings several times
data roaming is on, mobile data is on!
cannot think what else to do
running on android 4.1.2 but dont know when it updated to this..
Did you try the online configurator?
Or the Tweakker APN app?
See here:
If you still can't get it working post your settings here for review.
I'm assuming that you already have a data allowance as part of your membership or a data add-on.
Hope this help.
undefinedundefinedundefinedundefinedundefined
here are screen shots of settings!!
rock_chick
So I have restored factory settings and reconfigured internet settings using tweakker message!
Dey read as follows;:
mobile data is on,
data roaming is on
Apns: Internet : 48months.liffeytelecom.com - green dot is on
Proxy: not set
Port: not set
Username: not set
Password: not set
Server: not set
Mmsc: not set
Mms proxy: not set
Mms port: not set
Mcc: 272
Mnc: 11
Authentication type: PAP
Apn type: default,supl
Apn protocol: IPv4
Enable/disable APN: APN enabled
Bearer: Unspecified
@rock_chick wrote:
Mmsc: not set
Mms proxy: not set
Mms port: not set
Mcc: 272
Mnc: 11
Did you try the online configurator and/or Tweakker APN app instead of manual configuration?
Anyway...
Try changing the above to:
MMS proxy: 10.1.11.19
MMS port: 8080
Authentication type: None
APN type: default,mms,supl
and leave your other settings as they are.
Let us know if that helps.
This should configure a single APN that works for both internet and MMS purposes. In which case you can delete the second "MMS" APN that you have configured.
Did that help?
rock_chick
Ya just did dat dis morn, no good either! ! Had used d app but it just tells me to write down d settings n put n manually! Used tweakker online too where d send u d configuration txt! Thanks anyhow! Wondering if its a phone prob at dis stage! Thanks again!
