Lost my phone
ciera
I lost my phone and I ordered a new sim card but I want my old number back on it
8 REPLIES 8
See this key topic:
Need to swap your SIM?
If you ordered a new SIM then log a support request asking 48 to switch your account/number/membership over to it.
Guide on how to get help
Send them the 19 (?) digit SIM id number and the registration/activation code on the packaging.
A friend of mine did exactly this yesterday with a spare SIM and it all went smoothly and only took a couple of hours for 48 support to sort it out.
Let us know if you need further help with this, Ciera. Dalyers above links should be all you need! 🙂
ciera
How do I.go about sending them the 19 digit number thanks
You need to log a support request.
How to do this is explained in the second link that I posted above.
ciera
How do I log a request
Did you read the link that I posted above?!? 😐
ciera
I did but I just don't no how I go about login a request sorry
The "how to get help" link explains how to log a support request.
