Internet
My Internet isn't working?I have tried using the tweaker which has worked before but since I topped up this time it's not working, it will have the symbol on the top of my phone but if I go on to anything it just keeps loading, I have a Samsung galaxy S4
MMS Proxy: 10.1.11.19
MMS Port: 8080
MCC: 272
MNC: 11
APN Type: default,mms,supl
If not then change them as needed.
sophiephelan123
My internet on my phone isn't working, I have lots of Internet left, I have a samsung galaxy S3 mini, I never really had this problem before but I've tried everything and my internet still won't work, could you know what the problem it
Make sure that your settings match these:
http://community.48months.ie/t5/Need-Help/Internet/m-p/34478#M12545
If they do and it still doesn't work after a reboot then contact 48 support for advice:
